Very simple. Remove the bezels, then the radio, instrument panel, instrument panel surround, glove box, speaker cover panel and the dash. When the dash is disconnected pull it out a few inches and disconnect the wire harness from the back. 90% of everything uses 7mm wrench, a few 10mm and the speaker cover needs a torx bit, I forget what size. It took less than 30 minutes to get here. Took about 2hrs to button everything up when I was done with mods.
