1986 Buick GX1
GX1 #001 [The One and Only]
- Apr 24, 2015
I bought a used Racetronix 510lph double pumper to install (2) DW200's for running E85. I'm sure the DW300's would go in the same way.
The pump replacement was pretty straight forward. The wiring connectors were the same and plugged right in and the polarity was correct as well.
The challenge was going to be getting the larger base of the DW pump the fit the base plate.
I went to the local machine and welding shop and picked up a piece of 16 ga. 304 SS 2.5" x 4" and transferred the holes from the Racetronix base plate. I drilled the support tube hole slightly larger than .312 and drilled pilot holes for the fuel pumps.
I used a 1" electrical knockout punch (1.36") to finish the fuel pump holes. Once finished I used a cut off wheel to trim the base plate down, smoothed it up with a flapper wheel sanding disc and welded the collar on the plate.
I had to grind a bit more off in the area of the float arm for clearance.
With the pumps installed the filter socks were pointed directly at each other and were not going to work. All I found mentioning the correct filter sock was that it was different for the double pumper.
After more research I was able to give Mark at TR Customs a reference number and a description so he could get me the correct filter socks.
The half moon shaped filter socks are part number S147 and are listed for an '08 + Subaru. They go on with the flat side towards each other, but still require a bit of finagling to get just right. Yes the retaining clips are even worse to get on.
Normally I like to put them on with a small socket and push them strait on, but with the half moon filter sock it was necessary to put them on with a needle nose pliers. Spread the jaws just enough to catch the outside edge and work your way around.
As you can see the filter socks are about even with the float.
Since I didn't find much about the DW double pumper install I hope this helps out those who do this in the future.
