degreeing the cam
derek
87GN "Exoset"
I,ve read and heard that a cam should always be degreed when installing one and not to trust installing it "straight up" meaning just lining up the timing marks. My question is, is there a way to advance or retard cam timing on o stock Gn motor?
It is strongly advised for any motor.
derek said:
..... My question is, is there a way to advance or retard cam timing on o stock Gn motor?
Not an easy way. Retarding is easier than advancing.
To advance you can con purchase a, adjustable timing gear/chain set. Usually it will have both +2, +4 degree possible increments.
If you'd like to retard, you can file (Moon shape) the bolt holes in the cam gear a little. If you did this to advance the cam, the gear most likely will slip back to the stock position.
There are also off-center bushings on the market, but that is not real easy since you need to enlarge the holes in the cam gear to get it right.
