Hi everyone,
I bought an '85 T-Type a while back and just can't get it running right. The car was high milage, so I bought it to restore. It seems to run very well until I hit 1/4 throttle, then it just boggs down. The boost maxes out at 10 lbs and it is just not at all fast past 1/4 throttle. It really wants to go but the power just stops coming on. Below is a list of what I have done with the car. If anyone has any ideas what might be causing this, please let me know.
Rebuilt engine (1500 miles ago)
new TE-33 turbo
new Walbro 340 Fuel Pump/hotwire kit
dual 2 1/2" Hooker exhaust/mufflers
new 36 lb Bosch injectors and fuel pressure regulator
test pipe
3" up pipe (hopefully 3" downpipe soon)
new TPS sensor
cleaned out throttle body
9" K&N, 160 degree thermostat, Jay Carter chip
new plugs, wires, etc.
I checked the following:
no trouble codes on GM reader
ignition coil - OK
fuel pressure - OK
vacuum - OK
volts, temp, oil pressure - OK
TV cable - OK
Thanks for the help, I really appreciate it.
Chip
new TE-33 turbo
test pipe
new TPS sensor
ignition coil - OK
fuel pressure - OK
vacuum - OK
TV cable - OK
Chip
