I have an 87 GN purchased after it's been sitting since 93. Since purchasing I've installed the following: Racetronix pump and sending unit, plugs, plug wires, coil, TT chip with 60# injectors, caspers heated O2 sensor, LT1 Maf with translator, RJC 3" downpipe , test pipe and exhaust.
Scanmaster shows all numbers are within range I get a slight detonation at WOT. The turbo surges from 12-18lbs while at WOT with 93 octane. The car did this before all the new upgraded parts and I thought the upgrades would fix the problem. Does anyone know what else I could check. The only thing I can think of is perhaps a vacuum leak but if that was the case I think the scanmaster would show it. I did notice the cross count slowed after installing the heated O2 sensor. Any help is appreciated. Thanks.
