DFI Gen 6
dentmasters01
DFI sys. for sale with plug-n-play harnes. You can go extremely fast with this as this came off of Bill Ragland's "bull sh1t" car featured in the ATR catalog.
300.00 shipped.
Just remember when the timing shows 20 it actually 26 so tune accordingly!
From the dfi manual
1) Use an adjustable timing light and the
CALMAP software to verify timing.
2) There will be a difference between the timing
read on the harmonic balancer vs. the CALMAP.
The timing read in the ignition map will be the
actual timing and what is read on the balancer
will be twice what the actual timing is plus an
error of 12°. For example: 52° on the balancer
would actually be 52-12 = 40/2 = 20° actual
timing.
3) This variation in the reading is due to the
nature of this ignition system which incorporates
a waste spark firing.
If you use a non-dial back timing light, just a cheapie one then the actual error will be 6 degrees, becuase the dial back timing light douibles the way it reads the timing,
So if you run a gen 6 dfi you better check your timing compared to what the balance says, and you will find if you put 20 on your map you should get about 26 degrees on the balancer with a non adustable timing light and 52 with a dial back light.
Just to let everyone who is scared of dfi, that it will run great if you spend some time with a wideband o2 connected you can dial it in perfectly with a little patience. These old boxes were simple and effective!
Thats true and the car this DFI unit came off of (Bill Raglands) was a prime example. He never even had a w/band o2 on the car. Just the DFI and an EGT meter and the car was running 5.70-5.80 in the 1/8th at 120+.
