Originally posted by Craig Smith
Sure, I'm the FAST god.
I don't know if Racetronix is the Accel "God" or not, but he is really old.
Not as old as Chuck Leeper though! LOL The Racetronix guy should be able to help you with a 6.0 box. There seem to be a couple DFI guys on this forum lately as well. I'm sure they can help you.
Yes Craig, some days I do feel like the world's oldest man.
The day I start popping Viagra then I know I am going downhill fast. Then I will wish I was a god. I guess I can always buy myself a Vette when that happens.
Did someone day DFI 6.0. Is that like DOS 6.0?
All kidding aside ... The MSD EFI sync distributor for a SB Ford is P/N 2382. This distributor provides an inductive signal for both a crank and cam sync. Although you do not need the cam sync signal for your DFI, (not a sequential ECU) this distributor will have the required output(s) and adjustments to work with your ECM. If you decide to upgrade to a sequential ECM then the cam sync output will be there for you. If you go for the MSD 2382 you might want to consider the large cap & adapter as I have run into crossfire problems with the small cap version on higher HP cars. Make sure this large cap will clear your intake as on some Ford's this is a problem. Last time I spoke with the MSD rep there was no P/N assigned to the cap adapter for the 2382 so it has to be ordered by verbal description.
If you are on a budget you can buy a standard billet distributor with a single inductive output. This distributor must be adjustable so that it produces the proper crank timing signal required by your DFI. From what I remember, the base timing in the DFI's firmware was 6 degrees (Chevy) so if you set the distributor to 10 degrees your timing maps will be shy 4 degrees. That drove me crazy on the Buick systems. The distributor must also have the ability to lock the timing in order to work with an ECM (as Craig stated above).
You should make sure that your DFI is meant to be run with either with a magnetic/inductive pickup or with the thick film Ford module. It has been a while since I worked with a DFI 6.0 on a Ford but if memory serves me correctly the firmware and I/P on those boxes had slight differences??? FYI the factory distributor works well provided your DFI 6.0 is compatible with its output?
If you have the space the best option would be a crank trigger. A crank trigger produces a very stable timing signal and is not subject to timing error due to valve train slack (chain stretch & cam flex causing the timing to retard or jump around). The crank pickup is well isolated from high ignition voltages that can create interference problems with your pickup signal. You can use a factory distributor just for the spark distribution in this case.
I assume you have an ignition box such as an MSD6 to fire your coil?
Jack
Racetronix
PS If you drive that car on a regular basis you are going to wish you had a FAST system w/WBO2!
