differential boost control
jpwalt1987
for those of you using an external wastegate, what is your experience with differential boost control. (you know when you apply pressure to both sides of the wastegate diaphragm using an air compressor regulator). how steady is the boost pressure? how fast does it spool vs. just running one line to the bottom of the diaphragm? i have an ATR external gate that i am trying to get under control. i am thinking about putting my RJC boost controller inline with the regulator to take advantage of the boost control and spool characteristics. also i have heard that john craig works on the ATR gates to get them to perfom better. any thoughts and experiences would great. jeremy
My experience has been, that is in fact the best way to do it (dual port wg actuator)...
TurboTR
