Digital Dash and Power Logger Boost connections
Wanye716
Hello, I have an issue that is puzzling me. I have a digit dash Turbo T and I am trying to connect to the Power Logger for boost readings. I have purchased Alky Controllers TPS harness and a 3 bar map sensor. I have the 3 map sensor plugged into the Alky Control harness and the green wire supplied with this kit goes to the #2 port on the analog block supplied with the PL. Boost readings are not working. If I plugged the 3 bar map sensor to the Turbo T'S plug for it on the fenderwell and pretended that it was a GN, could I hook it up that way?
