digital dashes
chaparral
have question is the flex plate wiring behind the cluster the same for the digital dash as for the analog, meaning if i have a digital dash and the flex plate wiring is damaged on rear if i removed my stock cluster wouldnt that flex wiring still be the same just not used on the back of cluster, they didnt make differnt flex plate wiring things did they or use one general one and plug the bulbs in where needed.
do you know,
cause i have a digital dash now that the flex plate wiring on rear is damaged, really the surround is as well but thats it and im thinking i can replace that flex plate wiring unit n be good
any thoughts have any digital dashes around for parts
