Before doing that check 2 things.
First chack your dash lights. If the dash light control is flaky, it will sometimes cause the boost tach to not work.
Second. Open the hood. Go to the drivers side behind the alternator. In that bundle of wires running along side the engine behind the alternator you should find 2 wires. One brown with a brown connector and a green connector with 2 white wires. Make sure these are not plugged into each other. If they are unplug them and your tach should come back alive. This is a common issue too. Hope this helps.
