recently picked up a used DirectScan from another member. I'm having the same problems everyone else seems to have with XP. I understand DS will NOT work with XP, but I have not been able to create a DOS boot disk that will work either.
The hardware I'm trying to use is probably a little different than most. I've got a Dell D520 laptop which has no floppy and no parallel port. I searched this board a couple of weeks ago and found where several guys had managed to get a PCMCIA parallel port to work with DS. I bought a PCMCIA parallel port and installed the drivers so I'm able to connect everything.
The laptop is loaded with XP so I know I'll have to create a DOS boot disk but since this laptop has no floppy drive, it will have to be a bootable CD.
I have borrowed a USB floppy drive from work and created a bootable floppy directly off the laptop and then used Roxio Easy Media Creator to make a bootable CD from the floppy. The bootable CD works - sort of. It brings the laptop up in DOS, but it will not let me access the hard-drive (which is where I have DS installed).
I really don't have the cash to buy a dedicated laptop for DS and partitioning the HD for Win98 is not an option.
Anyone know what I need to do to create a bootable CD that will let me access the HD?
Thanks,
Rob
Thanks,
Rob
