Direct Scan Question...
I can't find the Direct Scan website anymore and I wanted to know if:
Does the Direct Scan have a way to sense boost?
Mike Washington
Chu Engineering Home Page
Direct Scan does not sense boost as provided, however, it 'CAN' be made to, provided you have your chip modified to through-put the data, and set up direct scan with the 'user defineable' parameters enabled and properly addressed. Eric at Turbotweak has provided this service in the past, although I'm not sure he still does it on a regular basis. Appendix 'C' in the user manual (available above) addresses the user definable option of directscan. Requires a definitive knowledge of chip programming to accomplish.... :wink: Hope this helps.... :)
