On a serious note..
Thats a T0220 case driver..only thing that could smoke one of those would be hanging on the main ecm connector..not the card edge..
I'd look for a wiring issue..you could proabably use an ohm meter from the blown drivers 3 pins to the main ecm plug and find the offending line..then figure where that line goes and hunt down the wire rubbing/shorting against something..
As far as the three pins on that driver..one will be its input,the other would probably be a source to it(pwr/gnd) the third is the output..and plugging in another ecm..will most likely fry it if the line is bad..
Could also have been light bulb effect whereas you hit the switch and the bulb in the bathroom goes out..sometimes parts just fail..but more likely a wiring issue in the vehicle..
And not the blinker fluid system
