DIS4 Box For Sale
what else is needed to use this unit? harness? etc.
and upon sale, does that contribute to us seeing the GN running down the track?:D
Just the interface and you're good to go! The GN will be ready soon ;) I drive it once a week killing everything in my area. hahaha I have my own 1/4 mile track behind the house and there's no cops. ;)
brent when can we see this bad boy at the track, i got the wagon on the road already under boost just gotta get the drivers side header fixed and find out this knock problem that i have at 15-20lbs of boost:frown: good luck on the sale:cool:
It's almost ready. I just need a few things ;) I drive it all the time...
So, why are you getting knock at 15-20 lbs? Have you checked timming is it too lean, is your gauge right?
scanmaster readings show knock around 15-20lbs on 91oct that could be my problem but i doubt it im running a A1000 fuel pump with 60lbs injectors the O2 readings are around 820 so its a lil on the rich side at that lbs. of boost :confused:
You can also see knock when its to rich. Hold on....are you seeing this in the 100+ degree heat we are having? If so that's your prob :p
