My combo is as follows...
87 GN, rebuilt motor with forged je pistons, girdle, mildly ported stock heads & intake, ARP rod bolts, studded throughout, comp 208 cam, hooker exhaust, 3" THDP, PTE44 with RJC and adjustable wastegate, TurboTweak street chip, MAF translator with LT1 MAF, stock intercooler with Mease neck, 009 injectors, hotwired walbro 340 (?), Art Carr Tranny with Art Carr 3000 n/l, voltbooster, richmond locker, 275/60/15 Nittos on stock tires with 5/8" spacers, no bags, stock suspension. FP set at 43psi base, TT tables bumped up about 8% at WOT
My best time of the night was 8.64@83.14 on about 16psi with 1 degree of knock in between the 2-3 shift and just a tad of knock at the beginning of 3rd gear after that. All the runs on the video were at 15psi except for the last and best run. My 60fts of the night were all 2.0's. Which I don't get because I brake boosted off the line as much as I could then floored it and hooked?
Car runs perfect driving around, no issues at all. I figure this thing should rip with it's combo. Only thing I notice is that it's a little fat down in the low RPM's but leaner as the RPM's go up (same boost) 830mV to around 760mV. Keep in mind the temps were around 80-85* with probably 85% humidity.
Only thing I can really think of is that maybe the TT chip was added before some of the work on the car was done? The things I have personally installed have been the LT1 MAF and translator, boost, knock gauge and scanmaster, cleaned the stock intercooler out, run a boost leak test and fixed all vacuum leaks. Everything else was done prior to me getting it. I have a meth kit installed and waiting to tune, but I'm waiting to sort this out.
I was hoping for some 8.10's@85-86+ for the night. The low mph is what has me wondering what's wrong.
http://www.youtube.com/v/BSwEuBMWZWI
