Distributor & Classic FAST
J-B Racing
Forced Induction
I heard that I have to modify my ECU to work with a Distributor! Is only FAST that can do the modds to the ECU?
Only a few early ecu's need to be modified. If your ecu is one of those and does not have the points activated you can do it yourself by adding a 0 ohm resistor to that circuit.
O.K. I will check that out when I get there. I will ask Stephan on Saturday when I go and get the S2 Motor. He said that he ran the FAST.
Thanks Cal
Joe
If I want to use a MSD 7AL. Is their an Adapter harness that I can plug to my Coipack Connector, or I have to splice!!
I am not sure what I am going to do..
