distributor swap
Trbobuick
Boost addict
Whats all involved to swap my car over to a distributor ? Can the stock crank sensor be used as a trigger ?
You will need an aftermarket ECU with IPU capability and a MSD box or equivilent, you can use the pickup in the distributor as a crank trigger with a bank to bank or batch fire but you will need a method to phase the rotor OR the better way o do it would be with an MSD flying magnet crank trigger, then the belt spacing issue...not an easy "bolt on" but worth it in my opinion on a high HP car, very reliable.
And yes, you can also just use the stock crank sensor and remove the CCCI coil module and use a distributor :)
TurboTR
If you are going to BG stop by the red turbo V-6 Camaro. I have a lot of the stuff you would need to do this (MSD distributor, pulleys, belts, brackets, etc.) I will sell this stuff cheap! I will also have a lot of other Stage II stuff for sale as well.:)
