Diy
Lets talk about this Shurflo pump. I had one on my car last year (model slv10-aa41 ) 12 volt --4.0 amp.--40 psi. It says to use a #8 spray tip or larger. It has the hose barbs molded into the head. I broke one of the barbs off ( my stupidity ) I now have a new one (same one ). Is this the same pump you are using? This pump is an external pump, a little larger than a stock intank pump. I am using methanol also. The way I was able to keep constant flow was to put a tee in the discharge line and return some of the alky to the tank. Steve at SMC was kind enough to sell me a tank and some fittings. Now I am looking for a source to purchase some of the aqua mist stainless nozzles. Anyone know where I can get them? Thanks
