First off I am new to this board but I post regularly on camaroz28.com. So far I have had a lot of help from Razor (alkycontrol.com), he is guru status mad props for all the help so far. I have been doing a lot talking with him about this DIY alky setup I'm trying to do. I was going to get a controller for the pump but I have decided to use a simple pressure switch until I start to push more boost. So far I have a SHURflo 2687 and a converted winshield fluid reservoir with a pickup on the bottom as an alky tank. I was going to run a Hobbs series 5000 pressure switch. It's a high quality pressure switch with an adjustable set point of 1.1-3 psi factory set at 2 psi with a tolerance of plus or minus 0.5 psi. Would that be a good switch to use or should I go for the switch that has a turn on set point of 0.5-1 psi with a tolerance of 0.3 psi??? That was my first question, which pressure switch.
Second question: what nozzle should I use??? M10, M15???? I want it to work properly pushing only enough alky for under 6# with the pressure switch right now and enough for say 12-15 after I rebuild the motor for more boost. Or two M10s??? Or an M10 now and an M15 later???
So those were two questions that I really need answered. Everything else has been taken care of. Thanks!!!!!!!!!
