Buick Turbo V6 Parts: Kenne Bell, Precision Turbo, Boost Leash, Vibrant Performance, Turbonetics, Crankshaft, Diamond Pistons, etc….
BUICKTIME
It's ah me, Mario!
TurboBuick.Com Supporter!
I need to make room, All these parts must go! I have plenty of pictures but limited to the amount of pics I can post. Just LMK what part(s) you're inquiring about and I will send them to you. Prices have been reduced to offload them but i’m opened to offers. PLEASE do NOT waste MY time, serious buyers only, PLEASE!!! Don’t hesitate to ask questions if you have any. Prefer Local pickup for the **bigger- heavier items. Local pickup is Oceanside (Long Island), NY 11572
If marked Shipped, price is to the lower 48. PayPal F&F, Add 3.5% if paying Goods and Services.
1– Turbonetics 6965 BB Turbo in great shape, large compressor housing with 4” inlet, 2.5” out, T4-4 bolt exhaust header flange with 3.5” V-Band exhaust out (less than 3k miles)_ $500
2– Boost Leash Kit with Dual Clipper boost solenoids, works perfect. Also comes with mounting bracket, quick disconnect fittings and some vacuum lines (less than 3k miles)_ $250 shipped
3– Moroso Dual Breather Oil Catch Can/Tank (Dual -12 AN bungs and drain plug) fits snug in the battery tray of a g-body (less than 3k miles)_ $30
4– Precision Turbo- PTE Turbo Saver Oil Relocation Kit (needs new filter_ less than 2k miles)_ $150
5– **Stock Crankshaft- cut .010 mains & .010 rods (needs to be cut)_ $100
6– **Stock Crankshaft- cut .020 mains & .010 rods (needs to be cut)_ $75
7– I have the Harmonic Balancer & SFI Flexplate (SFI exp.) that was assembled with this crank_ $225
6&7– Buy all 3 pieces (with/.020-.010)_ $250
8– Diamond Pistons (21403-6) 40 over with rings and pins (less than 3k miles)_ $250
9– Vibrant Performance 2691 Vacuum Manifold - Anodized Black- comes as pictured with 1 vac. line and 2 AN fitting lines_$70 shipped
10– 3x Billet Caps & ARP Main Stud Kit (USED)_$350
11– 86/87 Coil Pack, Module, MSD Spark Plug Wires, bracket and thermal boots (as seen in pics, USED in good condition) with custom plate_$250 shipped
12– Power Steering Reservoir- OEM left hand thread with chrome cap_$165 shipped
13– PAC ALKY Control parts (only what's in the pictures)_ $50 shipped
14– Driveshaft Loop_$80 shipped
15– T Type Horn medallion with rubber_$100 shipped
16– **84-85 Hydroboost Brake Booster (not sure of condition, was sitting for a long time)_$50
17– 2004R Sonnax Servo Kit (less than 3k miles)_$75 shipped
18– 2004R Trans Pan with drain plug (not the best weld job)_$40
19– Comp Cams 212-212- cam gear has some wear, not sure if it can be repaired (make offer)_$??
20– Dennis Kirban X-Brace_$75 shipped
21– Ram Air- Fiberglass Canister and ds air dam (no hoses or scoop, only the 2 items)_$35
22– Kenne Bell Ram Air with KB Plastic canister, filter and ds fiberglass Air dam that needs some fiberglass work to look presentable (needs hose)_$90
23– Aftermarket radio kit x2_$30/each shipped
Buick Grand National, Turbo Regal, T Type, Turbo T, G Body
86/87 Buick Grand National, Turbo Regal, T Type & Turbo T Performance Parts:
i'll post more pics later
