Originally posted by JrTuner
Or a dual sync distributor if you are using a distributor. If you are and you switch to a crank trigger, you will need to modify your distributor so it is a sync pulse. From your sig I would guess you race a Mustang. Accel has a dual sync distributor for Fords that makes setup a lot easier. Any EMIC could get you one, if you are from eastern part of the country you can call Berrel Auto in PA, they would glady help you out.
