Mar 6, 2008 #1 W Warrant Member Joined Oct 16, 2007 Messages 221 Just a quick simple question. the speedo housing in the back that you screw the speedo cable to, is that interchangable with Th350 - 2004r? Would the drivin gear happen to be the same? Thanks
Mar 6, 2008 #2 Turbo6inKY Short Guy TurboBuick.Com Supporter! Joined Jun 18, 2001 Messages 2,183 Neither the gear or the housing is the same between the two.
Mar 6, 2008 #3 W Warrant Member Joined Oct 16, 2007 Messages 221 Alright thanks.. they looked very alike in pictures
Mar 7, 2008 #4 S SRGN In Progress Joined Mar 3, 2007 Messages 237 You can attach your stock speedometer cable to the TH350 though, I just attached my TH350 cable to a 2004R trans in my hybrid.
Oct 11, 2008 #5 W Warrant Member Joined Oct 16, 2007 Messages 221 Will the bolt and little piece of metal that holds that speedo in work from th350 on a 2004r?
