Does a 2004r use the same speedo housing as a TH350
Warrant
Just a quick simple question. the speedo housing in the back that you screw the speedo cable to, is that interchangable with Th350 - 2004r?
Would the drivin gear happen to be the same?
Neither the gear or the housing is the same between the two.
You can attach your stock speedometer cable to the TH350 though, I just attached my TH350 cable to a 2004R trans in my hybrid.
Will the bolt and little piece of metal that holds that speedo in work from th350 on a 2004r?
