donut or connector GN 85
GnTooFast4u
I am looking for a gasket or donut that connect the down pipe with the turbo has a form of a triangle is for a GN 1985 3.8
You need a gasket for inbetween the downpipe and turbo?? The triangle gasket is used on the up pipe to turbo? Is this a stock downpipe? Should be able to get whatever you need from ATR, as they carry stuff for our turbo/exhaust setup. If its the downpipe then most likly you just need a 2.5in donut gasket........you could probably get that from you local parts store.
you can get a high performance copper gasket from poston for $7.88 the part # is #PE389743
