doore glass removal
wear long sleeves - I did it long ago and it seemed straight forward. It is a big piece of glass!
Door Glass Removal
Remove Door Trim,carefully Pull Back Inner Door Paper. Remove The Upper Glass Guides(10 Mm Head Bolts) And Remover The Rear Glass Guide Pin Bracket. Put Glass In The 1/2 Way Up Position If You Can,this Will Allow You Access To The 4 10 Mm Nuts On The Glass..remove Them And Pull The Glass Out An An Angle,its Nice To Have Someone Hold The Glass When Removing The Glass Nuts.. Not A Hard Job,you Should Be Able To Do It... Good Luck!!!
The procedure is as stated. I can post or send you the pages from the Factory Service Manual when I get back home tomorrow if needed.
