Forget bending the pipe. it would not line up with the cat then even if they could bend it without kinking. Best method is to mark the location of contact on the pipe. remove the pipe and using a large ball peen hammer, bap a shallow dent in the area marked. Does not affect flow enough to notice and will provide clearance. This is all assuming you have good motor mounts.
Mitch
