Is drilling the eight 1/8" holes in the OD steels neccesary? I will be spinning 6500 RPM.
For the 45* .060" hole to be drilled in the direct clutch housing, Does this hole go all the through the housing and out the bottom through the thick metal(or only through the first thinner layer of metal where the frictions are held? Is there a specific location for the hole? does it go through the corner on the inside and out the rounded corner on the outside? I cant tell in the picture
I will drill the lube hole on the front carrier to .125"
I will also drill the existing holes on the front internal carrier to .150 (this is pretty large?) However I wont drill holes in flats that dont have any. Satisfactory?)
And lastly for the .060" bleed hole to be drilled in the low/reverse clutch housing. The picture looks like it is in the outside 90* corner of the housing. Is the location specific? Should it be drilled at an 45* angle?
Any other holes that I should/should not be drilling?
Thanks!!!
Thanks!!!
