Measure one of your drag wheels, but I think the thru hole is actually a little over 11/16". My moser washers measure .700" ID (45/64). If the wheel fits tightly on the hub register in the center of the axle, then you can probably get by without a mill and cutting oversize won't hurt anything. But, you probably want to drill from the backside. Since the drill is a shallower angle than the acorn seat, drilling on the front would be next to impossible. Look at the angle on the drill vs. the lug nut and you'll see. The drill would only cut on the edges with nothing to center it.
