Jan 14, 2019 #1 D Dhos1 Self-tuning wanna-be Joined Apr 14, 2012 Messages 1,477 When I open my drivers door, the light doesn’t come on. It works for the passenger side-not the drivers side. What could be the issue. Thanks—
Jan 14, 2019 #2 grass doctor Dream Catcher TurboBuick.Com Supporter! Joined Sep 21, 2018 Messages 2,777 probably the switch https://www.highwaystars.net/switch-door-jamb-switch-driver-side-2-terminal-replaces-gm-25603977/ I would think they would both be on the same circuit so not the fuse but I don't know for sure maybe the connection corroded/bad
Jan 14, 2019 #3 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,016 Ground is probably corroded, ground comes from the mounting threads into the metal. Unbolt it clean it up make sure it's got good metal contact when screwed back in and try it. Other issue can be the plunger sticks in but you should be able to see that when you open the door. Third issue could be a broken wire on the switch well actually it would be off the switch. The white wire is the light switch tan wire if there would be alarm input with factory alarm system. Those wires don't like to be all twisted up so be careful when removing and reinstalling the switch.
Jan 14, 2019 #4 grass doctor Dream Catcher TurboBuick.Com Supporter! Joined Sep 21, 2018 Messages 2,777 do y'all s door chime still work
