SignUp Now!they look the same it ojnly does this when i hit second real hard when i feel around it i have 2 1/2 inches under the loop and 1/4 inch on top away from the drive shaftjpratt said:Are the rear tires centered in the wheel housings? Not front to back but side to side, do the wheels stick out the same from each fender lip? Perhaps the rear axle is shifted to one side. Mine was of a little and new upper control arms helped out a lot.
pacecarta said:had similar with my lkirban oop
mounts were new , HR poly driverside , pioneer passenger side ,
new trans mount
n mine there was only little clearance at the top , wouldnt hit all the time but it hit the back edge of the shaft yoke ears . would hit more when I had a passenger .
besides the driveline mounts my car has new body mounts but the frame might be tweaked a little so I cant blame kirban for my clearance issues .
you may have a sagging floor pan or body mounts
I ended up pulling the loop back out and modified it , cut grooves in the top where its bent to weaken it and at the top center and then bent it in from the sides with a BFH , when i was done it looked more like a roof at the top ,and then welded it back where i cut grooves.
other car has a metco loop (big ring) and has no issues .
