I wanted to mention that I've been driving the TTA with the Quicksilver shifter and I LOVE THIS MOD!!! I've got a stage-rite brake and a "good era" Brian Hoffer 200-4r, and this is honestly one of the most satisfying mods I've done.
The shifter is very precise, and it's easy to select the specific gear you want because it ratchets one gear at a time for upshifts and downshifts. It makes setting and releasing the trans-brake drastically better, and it doesn't feel like a cheap piece of plastic garbage like the stock shifter.
This probably isn't a good mod if you have a stock TTA, but if you have a trans-brake or like shifting without worrying about going into the wrong gear/neutral it's awesome. (I don't manually shift mine except for the 1-2 shift to release the trans-brake)
If you cut/welded the shifter and used a T-Handle and painted it dark grey it would look awfully close to a stock shifter at a glance.
