hammer4691
Hello 200-4r Gurus,
I come to this forum because I know the smartest 200-4r people on the planet contribute to the forum. I have read and read and read before posting. Here is my story :
I own a 66 Nova SS. It is a hot little street car, with a SBC and about 400hp with 3:73 gears. It had a TH350 but I wanted an extra gear. I knew of the great gear spread the 200 had to offer, I knew I wanted one. I pulled one from a junkyard out of a Cadillac and dropped it off at a local builder who builds trannys for a speed shop. ( not a 200-4r expert) He rebuilt the trans stock and put a Transgo shift kit with a billet servo and a 2000 stall converter. Originally, he put in a BR governor but it would never shift at WOT, so we put the original one back in. I have since lightened the small weight and it now shifts at a little better RPM. I'm still tuning that. I use a vacuum switch to engage OD and that works fairly well.
When in D it upshifts fine at light throttle, shifts are firm and at the right time. In D once I get to 4th it will not downshift when I go to WOT. The clutch disengages and the converter slips but it never downshifts. I also get the 3-2 clunk when coming to a stop. When I drive in 3 the shifts are a little higher RPM and I do not get the 3-2 clunk. It will downshift. All my shifts in D or 3 seem firmer at light throttle than WOT.
The TV cable is set up correctly and has the geometry extension on the carb. I did hook up a pressure gauge last weekend and got these readings at 1500rpm at 0 TV and Full TV.
P 80 165
R 150 200
N 80 170
D 80 170
3 80 240
2 170 170
1 170 170
Before I discovered this forum, I was naive as to all the valve body combinations and the precise calibration they need. It currently has a KC4 valve body. I'm done working with my builder. He's a great guy and might be able to build a th400 for race cars but he clearly doesn't understand 2004r and way too busy to spend the time with me.
Do any of you have suggestions or see anything glaring ? I see that Extreme Automatics can set up valve bodies to perform like a BR. Is that my easiest option ?
Thank you,
Mark
P 80 165
R 150 200
N 80 170
D 80 170
3 80 240
2 170 170
1 170 170
Thank you,
Mark
