Alright, now the ramchargers fans, even though they are out of business, that is still the same style you will go with, there is a slight gap in between the two fans. Now what i reccommend is that you measure the pipe to the "T" abd cut off as much you can that connects to th turbo, so it pulls the curved portion into the motor. The ramchargers dual fan set up is also slightly thinner and not as wide so between the two it should work perfect. Any other questions let me know.
