Dual Walbro/TI 415lph pumps in tank?
Eticket
Anyone tried it? method to getting it in, one pump at a time and then assemble to some extent?
I don't have the pumps yet. currently I have a dual 255lph setup in my car, I want something more E85 safe so I want to jump to the 415s... and just maybe i will need that much pump for e85 later..
thanks in advanace....
Like you I've been told they don't fit. I'll be curious to see if anybody has tried it. I ran a Bosch 044 in the tank with good results..... And that doesn't fit either so maybe it's possible. Dual aeromotive 340s (340l lph each) would provide quite a bit of fuel all the way into the mid 9s on e85 I suspect but I've heard good and bad about them with E85.
Twin DW300's drop right in without much fuss
Yeah that's the Same sizing as the standard 255lph pumps. He 450lph pumps are bigger at the bottom
I came up with a really good solution using internal and external setup...thanks..
