Toby_Goodmk
Test Fit officianto
- Dec 9, 2011
I have been trying to resolve a stubborn oil leak at the timing cover. It is at the upper bolt that holds the crank sensor bracket on. It appears it passes through an oil galley? I have dyed the oil and it points right to it. I have removed said bolt before on suspicion of the oil leak and used right stuff to seal the threads up...nope...didnt work. I am using ARP bolts, same thread pitch... Anyone else had this issue too? And if so what did you do to solve it?
