Make sure the gas cap is on tight; Evap codes are very common (P0440). You can turn the key on/off/on/off/on very quickly and it "should" show the code in the gear indicator LED area. If that doesn't work, turn key on/off 20 times (no kidding). Don't do more than 10 at a time because you are priming the fuel pump every time and it can hurt it. Rest for 3-4 minutes between. After 20 key cycles the code will clear if it's just temporary. If not, then stop at Autozone. They have DRB readers and will help you determine the problem code. Cooling fan relays are also common problems, moreso for the a/c condensor fan.
