- May 28, 2001
The coil may be on the way out and flow without fuel pressure on it may occur.This just keeps getting better and better. I took the #5 injector out and tested it with a can of carb cleaner, some vacuum hose, and applied 12v. The injector does flow, so now I have spark, compression, air, and fuel but it is still dead on that cylinder.
Bench test with high psi would tell the tale.
