AC Clutch not engaging 85 GN
Could this pigtail be bad?
Yes correct, doubt its the pigtail though. Keep it removed and powered on the blue wire.
I was mistaken saying this signal goes back into the dash area, it goes out of the light blue wire on the pressure switch connector over to the passenger fenderwell area to the left of the blower motor into a 4 cavity connector that corrodes often. I have pictured the 1987 page for the 1986 climate control but that 4 pin connector is in the same place. Should have blue wires on both sides in cavity A. Try the wiggle test to see if works if not put a meter on both sides of the blue wire to see if you have voltage when A/C is selected and the pressure switch in place, or you power the blue wire at the pressure switch unplugged.
That would be C497 from the wiring diagram. It needs to pass the signal through the connector to the relay.
I actually crimped on new male delphi metri connectors on the c497 plug yesterday as they looked a bit corroded. Also replaced all 5 male ends on the 5 pin connector on the ac/heat module that plugs into my new casper module. I will take a look here in bit. Thanks for the diagram. My c497 plug only has 3 wires..single, black, red, and blue.
So just to confirm, the 4 wires that are in the ac relay on the passenger side fender, pink/black(ignition12v), green/yellow(ecu A2) , green (to ac clutch), and the two light blues(B8ecu)...are all supposed to be 12v when engaged? There's no grounds in there? I took a look at the diagram below and that's what it looks like..unless I can't decipher and I'm wrong.
The light blue wires out of the relay ...1 goes to the pressure switch from relay and one goes into C497 plug in....so does it send a signal back into the ECM at 12v?
Out of the relay the light blue wire for compressor control power goes from the relay to C497 cavity A blue wire, to the other side of the connector also a blue wire directly to the pressure switch. If you put power on the blue wire at the pressure switch unplugged it needs to read +12 to a good ground on both sides of that connector C497. I would unplug it and if you get voltage on one side of the connector make sure it sends +12 out of the other side of the connector. Forget the relay wires other than the light blue forget the ECM etc. Blue wire from the pressure switch needs to pass power through that connector blue wire to the relay blue. Simple tests.
Check the crimps and the contacts on the connector for the light blue wire.
The second blue wire at the relay goes back to the ECM, when powered from the pressure switch +12 when the compressor is ON it tells the ECM the A/C is functioning and it bumps up the idle, no other function that I know so it's an input signal to the ECM not and output signal from it.
Okay I will tackle this tmrw.....baseball is starting!! Lol
If I was to put female terminals on the green and blue instead of the factory pigtail and plug them into the the ac pressure switch.....I'm confident it will be a 12v signal going to through the blue wires to the relay and into the c497. Do you think I would damage anything if I tried that.....only After I try your suggestions, if there is no change?
Thanks again
Ahhh okay. So it doesn't go back to the ecu with 12v? What voltage is the signal going back to the Ecu? I'll do the tests tmrw and post back. Thanks again
The second blue wire does send +12 to the ECM and it gets it from the pressure switch that "should" power the compressor.
The easiest test would be to unplug the pressure switch put +12 on the blue wire in the socket from the battery, leave the key OFF and make sure that +12 goes through C497 blue wire to the relay blue wire. Use a meter at each location, black probe on a good ground, and find where the +12 disappears on each blue wire in the circuit including crimps and the contacts in C497. No harm to the system if the pressure switch is unplugged.
To power the blue wire just strip some 18 gauge wire and inch, fold it in half and shove it into the rubber connector socket, unplugged, with the other end going to the battery.
Okay sounds good.....very clear. Thank you
Okay so I just finished checking everything as the suggested above and the blue wire from the AC Pressure switch connector (disconnected) with 12v directly from the battery shows 12v at the c497 blue terminal and also at the Relay connector.
But when I run the 12v through the ignition in the run position and I jump the Ac pressure switch it brings the volts down to 2.69volts across the jumper and the c497 connector and the relay connecter where the 2blues go in.
Seems like the connector that plugs into the switch is lowering the volts once jumped/connection is complete. I wonder if there is a diode or something in the connector that is lowering the voltage when crossing from green to blue???
Wondering if I should cut the ac pressure connector off and put on regular terminals and see if that works. As long as 12volts dont fry the B8 Light Blue pin on Ecm.
Your thoughts.
This is strange.....now my green and yellow wire(A2) isn't getting 12v at all to the relay.
Also when you look down the centre hole of the AC Pressure switch plug does it look like a slot or something?
Disregard this...12v show up at green/yellow wire when the car is actually running. I was checking earlier with the ignition in the run position.
So I put a 12v directly to the blue wire on the ac pressure switch connector and the clutch does engage while car is started.....I plugged the switch in and put 12volts at the relay as well on the blue wires on the bottom side of relay wiring and it engages the clutch as well.
Need to check the light green wire at the pressure switch for +12 when A/C is selected.
Sounds to me like the blower and A/C clutch control module is shot not sending enough current out to engage the clutch.
If you don't get +12 at the relay blue wires with the system engaged, and as you found the wiring is good, the control module can't provide enough current to turn on the clutch.
I would get a trunk light bulb which draws about one ampere of current, put two wires on it by soldering or use clip leads, one lead to battery ground, the other lead to the light green wire on the pressure switch disconnected and see if it lights up when the system is properly set to turn on the A/C.
If the bulb won't light up brightly I would say the control module is shot.
Testing with a meter doesn't draw the kind of current the clutch would as a voltmeter is designed to be non-invasive testing (no load on the system) but the lamp test at the pressure switch will draw some current and if it doesn't light and the light green wire reads low volts the clutch control module is bad.
If you have a working hood lamp, make sure it lights up with the hood open, leave the hood open, disconnect the little connector near the wiper motor and put a stripped wire into the lamp connector and the other end into the green wire contact on the pressure switch and try the A/C. Same as sourcing a test bulb assuming the hood lamp always works right.
This is what I use for a test lamp that draws some current.
I used my hood light...it didn't turn on at all. Crazy..it is only 3 months old from Caspers.
I messaged them and they sent me a new one at no charge. Fingers crossed that the AC/Heater Resistor module is the issue. Should be arriving tmrw.
One side not....I got my hands on a pair of 100% functional Electronic Climate Control Units and a stock Ac Heater Resistor Module from a guy out in Red Deer Alberta I know they work as I tested them out in a buddies T-type...haven't tested the ac Module as it's still on its way here.
Update:
I just received the new Casper replacement AC Heat Module. Installed it, put the car in Run and thentest light lit up bright on the light green wire at the connector. Fired up the car and put Auto high at the coldest and the clutch engaged and blowing cold.
I am dumbfounded that a casper replacement part that they said has almost no returns failed on my car after less than 3 months.
SALVAGEV6 ... I just want to say thank you so much for all your help in helping me diagnose everything and to help me get the cars AC working again. Thank you.
