Captain Mark
- Oct 28, 2002
OK Razor, and you other guys that do this. I tried this again the other night at the track, with no success.
I have rear discs, does that make a difference?
As far as I know they still have the stock pads on them. Do I need to switch brake pads?
If so, which pads do I need to get?
The GN boys I know that e-brake, have rear drums.
I am cutting 60's in the 1.73 to 1.8 range depending on the track prep. Currently launching at about 5 psi. That is raising the boost as the tree comes down, not holding the boost at a constatnt level after staging.
Thanks as usual.
Thanks as usual.
