E85 vs pump gas w/alchy
Yes a member on here has dynoed tested both setups. I'm sorry I can't remember his member name.. maybe he will chime in.
Basically an 8% gain was noticed in favor of the E-85 setup without changing anything but the fueling. If I remember correctly these numbers were repeatable using different cars.
EDIT : Ok I found the thread here that mentions the tests: http://www.turbobuick.com/forums/e8...600-rwhp-e85-what-would-i-need-convesion.html His name is Quick86GN
Hopefully I haven't mis-quoted the test results. Again maybe Quick86gN will chime in and give us details.
HTH
