Eagle Rods anyone? Which way to install
Jan Larsson
Anyone using the Eagle H-beam stock length rods and can tell me which way they go? On side of the large end is bulging out if you like so the bearing is slightly off center. Which way is facing the front of the engine when I install these? Can't find any info so thought I'll ask :rolleyes:
Rods
The easist way to remember is that the bearing tags go toward the pan rail.
The offset on the big end of the rod is facing the counterweight.
Thanks Dan, that will help getting them installed correctly!
Anything I need to consider / double check with these rods like clearences or similar. I will check but thought I ask as I have no experience with the Eagle rods
check your rod side clearance that spec should come with the rods and may not be right especially if your mix and matching aftermarket and / or stock rods /crank etc...hth...noah.
