Just bought a used one. Wondering if anyone has any pics of one installed. Not sure of pipe routing and which is for left or right. Also where to bolt it up to. Any help would be helpful.
Here is their website. You should be able to get them to fax you a copy of the installation instuctions. I don't know if this will help but here is a view of the pipes. The intercooler is mounted using studs, hanging in front of the radiator. Take your grill out to do this. I drilled two holes in the header panel support for the studs to run up through. The nuts will be accessible from the top of the header panel in front of the top radiator support. I used lock nuts (plastic insert) so they would not back off. I also had to "clock" the turbo to make the pipe line up. They do make two different pipes that run from from the turbo. I bought a used intercooler also and it came with a pipe for an external waste gate. I run a THDP so I had to buy the other style pipe from ESP for an internal waste gate to install mine. It will be much easier if you have help when mounting it.
