V6UnderPressure
The Artist FKA Scott4DMny
- May 27, 2001
Anyone using this stuff? Sounds like a good alternative to revamping your entire fuel system to accomodate the corrosive effects of E85.
From their website:
Don't let Ethanol in today's gas damage your vehicle!
Eastwood's Fuel Guard additive system prevents the harmful effects caused by Ethanol and prevents corrosion, gumming and resin build-up. Use Fuel Guard Protection formula with every fill-up and Fuel Stabilizer formula for storage up to 12 months
•Prevents Ethanol Phase Separation and the harmful impact of Ethanol blended fuels
•Stabilizes Ethanol-blended fuels
•Prevents corrosion in the fuel system
•Helps remove water
•Keeps stored fuel fresh for easy starting
•Protects against gum & resin build-up
•Prevents clogged carburetors, injectors, filters & fuel lines
•Compatible with all 2 & 4 stroke engines
•Contains no harmful alcohol or hydroscopic additives
Eastwood Fuel Guard Additive - Daily Driver Formula
From their website:
•Helps remove water
