to be clear they are both eaton , the first is GM factory installed eaton, the second is an aftermarket eaton and is much stronger than the GM unit and because of the spring pack it can be had with 200# or 400# preload springs (the 400# can feel clunky like a spool at times ) or in the moroso unit you can get it with 800# preload spring
that factory eaton with the S preload spring was about 100#
the aftermarket eaton takes larger bore carrier bearings than the factory unit , the larger bearing is often called 'spool' or 'eaton' bearings when you purchase a complete install kit with bearings and shims
the stock gm was 28 spline and the aftermarket can be had 28 or 30 spline but
i would not recommend 28splines , even 28 aftermarket axles , for 1.4 60s so the aftermarket 30 with new axles would be the minimum i would want to see ,
the 30s are tougher but not unbreakable, only step up from there is the 33spline axles but you would need to do a spool and eliminators for those axles because they dont make a posi to fit them with the 8.5 rear
