SOLD
ttypewhite
Selling a good set of 28 spline Moser axles with pressed on C-clip elimunators ready to go. Reason for Selling is because the Eaton carrier is rebuildable, so I changed out the side gears to 30 spline and upgraded to 30 spline Moser axles with new C-clip elimunators. Axles and splines are in perfect condition with no issues. The only thing it would need would be a new set of axles studs as a couple of them have been cross threaded. This is great for guys with stock rear ends that want an upgraded stronger axle. There is work that is needed to be done to your 10 bolt housing to accept it. Lots the videos on YouTube to show how it's done. This upgrade with the C-clips avoids you losing your wheel and all the damage to the body of the car if you break an axle. Keeps all the carnage in the rear-end. Buy with confidence. Asking $350
