84buickregal
- Jul 16, 2008
my ebrakes dont work, does anyone know how to change the ebrake cables?
SignUp Now!ebrake comes in 3 sections.
1 from ebrake lever to mid of car in front of rear axle
then second peice joins onto that and goes to drive side drum
3rd peice goes from bracket on 2nd peice to passenger drum
there are tabs on the ends of the brake cables that need to be pushed in with pliers or flat heads before u can pull them out., easier to use a socket to slide over end peices to push all tabs in at same time
