Ecm 85-87
NorCalTurbos
Slowing down to SPEED UP!!!
Is it possible to use a stock 87 Maf when changing the ecm I have a brand new one or is the translator the only way? Thanks for any help
87 MAF will only work with 87 style ECM and chip. You can use an 85 MAF on an 87 car IF you recalibrate the chip. The MAF's are calibrated differently between hot air and intercooled.
Also, you can use an 87 ECM on a hot-air car, only with a specially prepared 87 chip (using the 85 MAF).
And, you can't use an 85 chip in an 87 ECM, and vice-versa.
Ok, good to know. I have the 87 ecm & maf so all I need is a chip from TT and I should be good until the reman maf TAS :poop: On me lol
