Thanks Fryguy.
I could go through the list of benefits of MS3 over the stocker but i feel this would be wasted time so ill cut and paste the benefits from another thread i made... Stroker-Ace I think you forgot to mention the $500-750 tuning software you'll need for a stock ECM. Houseofspeed, those types of controls (P/N "clutch in" rev limit) and the like are primitive and don't work very well... We have run a stock ECM on one of our boosted vehicles and many other swaps and they work great but leave a lot on the table.
Benefits (cut and paste I'm sure there are others..):
-No MAF speed density (NOT MAF Failing to trick ECM into SD)
-Wideband A/F Correction during normal driving (EGO Correction)
-On the fly; tune switching (3 tunes), and ECM flashing on the fly
-Electronic Boost Control
-2 Step and 3 step
-Ability to control Fuelab digital fuel pump for output control
-Automatic VE table correction, using WB02
-Ability to use GM flex fuel sensor
-Lean Cruise
-EGT input for datalogging and high EGT protection like de-rating, lower boost/timing
-Alcohol Control
-Nitrous Control
-about 12 extra Output control for just about anything
-About 6 extra input controls for anything
-Ability to run 16 injectors, for example bringing 8 in under boost.
