ECM Mods for Powerlogger
mzunino
What exactly does it entail?? Can you damage the ECU doing it? Considering buying so I want to get an idea
You are only cutting open the case. Anytime you work on the box you could mess-up the electronics part if you are not careful. You have to rub off the protective coating on the data plug like you would for a directscan.
It is pretty easy in the scheme of buick mods.
I just installed it and it was a piece of cake. I still need to get it reading MAP and wideband AFR.
Mike
